An IS is sending ISIS PDU's to the switch using a protocol not supported by this switch. The sender is using the mac address specified and the PDU's are arriving on the specified vlan. These packets are being ignored by this switch.
Neighboring ISIS routers should not be configured to send PDU's using the specified protocol as the protocol is not supported on this switch.
Notice
Dropping PDU with unknown proto %proto% from %srcMac% (%srcIf%)
| Name | Type |
| proto | xInt8 |
| srcMac | srcMAC |
| srcIf | VLAN |
